What is this part?
OntarioCanada
48
Ontario, Canada
Hayward Aqua Rite Pro (T-15)
Ok so I have done this many times but when I moved the diverter value to VAC couple days ago and hooked up manual vac hose on the VAC port in the pool and finished cleaning the bottom of the pool, this is what I found in the pump basket. It’s bit yellow making me think it’s been there exposed to water for a whole but can anyone tell me if this is some debris that was probably sitting in the vac return line or something part of a fitting somewhere? It was not in the pool when I vacuumed.
It’s rubber, flexible, round with a lip on one side.
Google lens brought this up 🤷‍♀️
Can you fill out your signature with all your equipment & pool details?
may help others figure out where it might have come from.
It’s not that, mine is thinner and I have color logic led lights that are very small in diameter. The rubber ring I found is about 12 inches in diameter.
Trying to figure out what’s missing in the signature and where to go and free text. Is that under About Me?
Do you have a Polaris pool cleaner?
