Hello! I am finally hopping on TFP because of all the issues that began last year and continued into this season. Sorry for the extremely long post.
Here is the problem that I CANNOT seem to fix no matter what I do. Last year mid summer, the pool got a little hazy and had a green tint. I shocked and scrubbed. A bunch of dead algae was at the bottom the next day. It’s like dark sand except it turns into a cloud when you push it around. While the water cleared up, the dead algae at the bottom has not stopped showing up since. I have triple shocked for days in a row, scrubbed, algecided, vacuumed to waste, everything I can think of but the stuff just won’t go away. Leslie’s told me mustard algae and gave me copper Algecide. I finally seemed to get it under control for about two weeks last year, but then it started up again.
I was REALLY REALLY hoping that the winter would put an end to it and it wouldn't be an issue this year, but no. Same thing. I’m ready to give up and just join the community pool at this point.
Because I am still fairly new, I never rinsed the filter after backwashing. I honestly had no idea that was a thing I was supposed to do. I put in filter balls instead of sand two years ago. I’m wondering if this stuff is just chilling in the filter balls and I can’t get rid of it. Can all of this just be because of not rinsing? I rinsed really well last week, but when I put it back to filter, a nasty green cloud came out of the returns. I tried rinsing until that stuff stopped coming out, but I would run out of water because it didn’t seem to ever stop.
I intend to shut down the pump on Friday, take out the filter balls, and put sand back in, but will I end up just introducing this Crud into the sand? I bought some thing called “Revive” and was going to give that a try. My plan was to let it do its thing, vacuum to waste, and then immediately change the filter over to sand.
I tested the chlorine overnight last night and it held at 5 (yes, I know that’s high) and the CC was .5 I think. PH was 7.4, alk 120 (that seems weird because when the pool store tested it, it was fine), and CYA 53. I just got my Taylor test kit and my readings from last night were legit the first ones I’ve ever taken so there could definitely have been some user error. Also, I’ve had perfect test results at a pool store when all this was going on last year.
The water LOOKS great! Clear, blue, sparkly, but all that Crud is always on the bottom after shocking or brushing. PLEASE HELP ME! What do I do?!
