If I recall correctly, high chlorine can mess with the PH test, so your PH may not really be 7.8. I'd let's the FC levels drop & retest once your FC is below 10. Your target for FC is 8-10, so it should drop into that range in a couple of days.
TA is high. You can lower this with Muriatic acid. This will also lower your PH. You can raise PH through aeration. I've been following this advice- let PH rise to 7.8, lower to 7.2 with acid, raise to 7.8 by aerating, lower with acid & repeat until you get to the desired TA level. Aeration raises PH without affecting TA.
Your CH is high for a vinyl pool. I think the recommended level is around 150. The only ways to lower CH that I've heard of are water replacement (assuming your fill water has low/lower CH), or a reverse osmosis filtration system.
Overall, I think you're in pretty good shape. I understand there can be some user error while learning how to use the test kits. I know I messed up a few times. I've read that static can affect the PH test droplet size too, so it's recommended to wipe the tip with a soft cloth for the first few uses.
Maybe perform a few more tests before trying to make any adjustments. Just don't let your FC levels get lower than the recommend levels!
