Smooth, slick, and slimy.What does it feel like when you run your hand over it. Ideas @Texas Splash
It's algae.Smooth, slick, and slimy.
Thank you. Will begin the process.It's algae.
Do you have a test kit? If not, get one now. Link-->Test Kits Compared
If you don't, add 5ppm of liquid chlorine per day until it arrives. Brush a couple times a day
If you have one, then start this process...Link-->SLAM Process
The slam process will put enough HOCl in the water to kill the algae. As you brush it, it will break the biofilm on those areas allowing the HOCl to kill the algae. They will come off as you slam and brush (you may have a stain, but we likely can resolve that too).
Don't attempt a slam without a test kit.
What test kit do you have?Thank you. Will begin the process.
None. I have to order one to begin the process LOLWhat test kit do you have?
Great. Wise choice. I would recommend the smart stir. Doesn't matter where you get it. It makes testing incredible accurate and repeatable, and even fun and easy.None. I have to order one to begin the process LOL
