Stoopalini
- Jun 8, 2020
- 442
- Plaster
- Pentair Intellichlor IC-40
Good job. I'm not sure if it applies in this case, but when tiling, any change of plane should be caulked, not grouted. Seems to me it should have been caulked all along.I'm doing the most miserable job in the past 3 years. The acrylic chalk line between the coping and tile was falling out. My tile is pretty tight in most areas around the pool so it was hard to get it in good. I decided to scrape it all out and use matching silicone for submersed use. I'm almost done scraping it all out laying on my stomach head over in the pool. I did 50' feet or so last night just to make sure it will look proper. I'm happy. Hopefully this time it stays in. I'm assuming it should cause silicone holds up awesome. tonight i finish scraping and then clean the bottom of the pool cause it's a mess! i'm just letting all the scraped out bit fall in the water.
edit: tonight finished scraping out and got pool all cleaned out. Checked all my tile. Not one cracked grout line thankfully after 3 seasons now. Tomorrow I tape off and Saturday silicone after I fish of course.
View attachment 161953View attachment 161954
It was caulked. Acrylic though. Typical like wall to floor in showers and such. It fell apart. So I replaced it with silicone based vs acrylic. This should hold up very. Well now.Good job. I'm not sure if it applies in this case, but when tiling, any change of plane should be caulked, not grouted. Seems to me it should have been caulked all along.
Ah I see that now that I re-read your original post.It was caulked. Acrylic though. Typical like wall to floor in showers and such. It fell apart. So I replaced it with silicone based vs acrylic. This should hold up very. Well now.
Is that one of their replacement bulbs? Looks nice.Here you go Skippy![]()
Yes it was the replacement bulb for Pentair.Is that one of their replacement bulbs? Looks nice.
That’s awesome! Did you add new lights or replace 120v bulbs with LED bulbs? I’ve been considering the latter, but can only find the large pool bulb, not the small spa bulb.Just added LED lighting to pool and spa from Florida Sunseeker Lights. Looks![]()
I did that as well! The original Pentair unit died (apparently no great surprise) and HUGE improvement and easy to do.Just added LED lighting to pool and spa from Florida Sunseeker Lights. Looks![]()
I replaced the bulbs 120v to LED. They had 2 different wattage choices on the big bulb and the spa light LED replacement is only 1 size and wattageThat’s awesome! Did you add new lights or replace 120v bulbs with LED bulbs? I’ve been considering the latter, but can only find the large pool bulb, not the small spa bulb.
There's a pot of gold there. . .Does this count? Less than a week after completion, this shows up over our pool![]()
I can't imagine having to deal with ash everywhere. But better that than fires your way. Your waterline tile is unique - Love it! Was that a custom job?I swept up about 3 gallons of ash from the patio and deck. I imagine there's about that much in the bottom of the pool awaiting vacuuming, but I'm holding off until the fires slow down because I'm sure I'll have to backwash immediately after and I'd rather do it only once.
It was here when I bought the house.I can't imagine having to deal with ash everywhere. But better that than fires your way. Your waterline tile is unique - Love it! Was that a custom job?
I'm curious, too. Did you drain the pool and put in some storage containers to support the cover?What’s in the middle under the cover? Are those floating, or do they go straight to the bottom of the pool?
