I have a 30000gallon, in-ground, Gunite pool. Have been struggling with yellow algae for the past two years. May have had balance off for at a time to let the yellow stuff in, but since discovering the problem I’ve checked the chemistry weekly and kept in balance - Chlorine, Ph, CYA, everything. Have also done the yellow-out treatment three times but the yellow stuff keeps returning. Now, coincidentally, I need to have my pool resurfaced which means it will be completely drained and the old plaster blasted off before being re-plastered.
I am, on the one hand, hopeful this will help with the yellow algae problem, but fearful on the other hand that I will have the same problem when the pool is refilled after re-plastering. What can I do while the pool is empty to help get rid of all the yellow algae - what may be in the pump, the filter contained (cartridge filter) and all the plumbing that leads their way? Is there anything I can do to flush these out effectively while pool is empty?
thanks
thanks
