What are these in CH test?
bere
0
54
Mont Belvieu, TX
I’ve been testing and maintaining my pool the TFP way since it was built and lately I have noticed these pink floating specks when I test for CH. Is this normal? Are my reagents bad? Is it because I switched to salt? Help!
That’s odd...have you been rinsing your tubes and pill? Try rinsing everything well with a little bleach and see what happens. Thanks for going down the TFP road!
Usually called floaters. Typically, caused by metals or other interference.
The sample may turn purple during the test, or go to blue for a moment and then turn back to red/pink. This is called a "fading endpoint" and is caused by interference from metal ions. If this happens, do the test again, but this time add five drops of R-0012 before adding any R-0010 or R-0011L. Remember to count the initial five drops in the total.
In extreme cases, a fading endpoint may occur even when adding five drops of R-0012 at the start. If that happens, mix pool water with an equal quantity of distilled water, test that, and then multiply the result by two.
