H haroldo Active member Apr 15, 2025 29 Salinas, CA May 5, 2025 Add bookmark #1 Are these $10 TDS meters ok? I want to measure TDS of my tap water, wondering if these are ok or if I need to find some more expensive test kits? https://www.amazon.com/TDS-Water-Quality-Tester-Temperature/dp/B07GNMY8ZH/ref=asc_df_B07GNMY8ZH?mcid=f2ada5cca43438d5a40b8182beee043e&hvocijid=17774479283005427243-B07GNMY8ZH-&hvexpln=73&tag=hyprod-20&linkCode=df0&hvadid=721245378154&hvpos=&hvnetw=g&hvrand=17774479283005427243&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9031887&hvtargid=pla-2281435181178&psc=1
Donldson TFP Expert Gold Supporter LifeTime Supporter Jun 12, 2009 6,073 NW Ohio May 5, 2025 Add bookmark #2 What are you hoping to learn from knowing the TDS of your fill water?
H haroldo Active member Apr 15, 2025 29 Salinas, CA May 5, 2025 Add bookmark #3 Donldson said: What are you hoping to learn from knowing the TDS of your fill water? Click to expand... I'm looking into a inline fill RO system, which has a feed spec of 2500ppm max TDS https://www.purewaterindustries.com/wp-content/uploads/2023/06/PWF-SERIES-FILL-LINE-2023.pdf I'm in contact with the owner for a quote, and he asked me for this info
