Our pool did not have a weir door and I'm trying to replace it. I've found the right replacement part to order, but couldn't see how it would attach. I think I've figured out the issue and wanted to see if this sounds right.
This is the OEM replacement weir (a door and the hinge):
I believe that the hinge is usually installed flat against the bottom surface using screws. I think that when it was installed in my pool, it was plastered in vertically and the hinge is still in there. Would you agree after looking at these pictures?
I'm thinking the easiest (maybe even only) way forward is one of the ones held in with tension.
