I’m a new hot tub owner. A friend with a pool directed me here to learn about the chemistry needed. I’ve followed the sticky for chlorine at the top of this section.
I’m currently on day 8, on initial fill I used 10ppm chlorine then every day I’ve been testing and before and after every use. I just reached 34ppm dichlor and am about to switch to straight pool bleach.
What I’m trying to figure out right now is in the sticky it recommends shocking to 12ppm once a week. Would I be shocking with dichlor/bleach or non chlorine shock? If it’s chlorine how do you work that in to the schedule so you can use the spa 7 days a week. If I were to shock to 12 I’d probably have to wait 2 days for it to come back down to 6ppm FC.
Is this something I need to be doing if I’m checking and adding chlorine every day?
Thanks for the advice!
