I have a Hayward AQR 15 that is starting on its third cell after I’m guessing 5-6 years. The cell that’s currently on there I had as a replacement, which I ended up never using, but it only had a one year warranty. i’ve had the cell for a couple of years, so there is no warranty on it, all the way up until now I never used it. About four or five weeks ago, the second cell died. so since I had this I thought I would put it in, and when I did, it seem to work just fine. But now even when the cell is at ~90% setting, and runs for 14 hrs per day, after four days is down to 1 PPM With no swimming. (I was out of town) My pool is only approximately 13k gallons, so this T15 is plenty big. I checked my salt with my k-1766 kit and it is at 3600 ppm. My question is, the little salt sensor that installed after the discharge in front of the cell, how do I check it to see if it’s good? Not sure if that would be causing the problem, but the control panel and that sensor or original equipment. Any ideas if the sale possibly is going bad?
GLX CELL 15-W
Readings:
3600
85
25.1
6.96
93P-3500
AL-0
R 1.59
T-15
Pentair Variable speed 1800 RPM
GLX CELL 15-W
Readings:
3600
85
25.1
6.96
93P-3500
AL-0
R 1.59
T-15
