Have a 2015 Hot Springs Pulse with No Fault Heater. I believe the pressure sensor went bad. I jumped the sensor and the heater works. Can I leave that jumped? The replacement heaters have NO pressure sensor and have you bypass the presssure switch at the board. Are the new heaters different in some way that allows that? Or can I leave the pressure sensor bypassed on my original? It Still has high limit and thermostat sensors.
