- Aug 9, 2017
- 154
- Plaster
- Pentair Intellichlor IC-40
Ok, we need to finalize more materials, most importantly the waterline tile which we also expect to use for a raised bond beam water feature at the end of the spa.
I lined up a slew of samples and lined them up against what will become the water feature wall. The light was changing fast so I took a few pics as the sun started heading down and also at slightly different elevations. The wall basically faces due west so the irridescent ones catch the light pretty fierce. I just can't decide if that is too much bling.
The water feature wall is 'flat' right now -- they screwed it up -- but the middle will be recessed and the recessed part will be tiled with the waterline. The rest of the surface we expect to tile with a wood-look tile. I took a couple extra floor panels from our house flooring which is similar and just stood them up on either side to give some context...so, it will look like a fairly dark but warmish wood around the sides and top, and then the waterline tile in the recessed area.
We're planning a sheer descent at the top of the waterline tile to drop three feet down into he spa but we may end up going with a straight drop rain effect which is more what is depicted in the architectural drawing.
The wife's favorite in the store was the 1x4" tile that is sitting in front of a few samples in the middle (and then put on top in the last pic)...but I feel like seeing them in the sunlight totally changes things so my guess is she will feel differently tomorrow.
It is pretty amazing how different these things looked even over the course of 30 minutes or just shifting angles.
Our colors are generally muted everywhere...a very pale beige floor (R11 porcelain), an ipe wood deck, wood-look tile on the exterior side of the pool (the pool & spa are both raised 18" above ground), dark grey concrete coping...the waterline/feature tile is really the only 'bling'.
FWIW, haven't decided on pool surface material or color...looking at aquabrite, tile will probably determine color.
Lastly, the builder is complaining about recessing the spa wall as it was drawn...obviously he'll have to fix the work that was messed up but in addition to that, he's looking at quite a few mitred cuts on some pretty small cuts of 3/8" porcelain tile which he is none too thrilled about... I'm not sure how far to push it. Can you sit comfortably against a straight wall? I didn't realize it until now but he just completely 'missed' that the feature isn't supposed to sit on the pool bond beam, it was supposed to be built behind it.
Opinions on tile??? Opinions on whether I have to make him redo the spa water feature wall?
