Does your waterfall get filtered water?
If you see gaps in the waterfall stream, debris has lodged in the opening of the waterfall, or the water flow is too low.
Use a credit card or similar object and gently position it inside the opening while the waterfall is on. Slide it along the opening to the point where the debris is located and gently pull the debris through the opening. Do not use a metal tool.
If there is no debris in the opening, clean the filter and filter basket and check the position of the flow valve to the feature.
