I would like to plumb a pre-filter like the Multicyclone however I have a DE filter and cant seem to find a diagram as to how I add a bypass when adding DE. Also can I place the Multicyclone after it runs through the pump just prior to entering the DE filter or will that lower the pressure going into the de filter? Or does it need to be placed on suction side prior to entering the pump? I'm asking because to plumb prior to entering the pump would require extensive plumbing along with moving the pump. Any help I would truly appreciate!
