I am suspicious the water pressure switch is going bad. The story: I installed a new vs pump this year, the 7 year old rheem heater worked fine for the first 2 months. I found a low speed that satisfied the heater and it ran fine at this low speed, 11 gpm. Last week I found the error message water sw open, kicked the flow to 15 gpm and it ran fine. Kicked back down to 11gpm and it shut down, water sw open message. Today I had it running at 15 gpm and got the error message. The heater would light, run for a minute, then shut down. It would repeat that process ending with a water sw open error. If I kick it up to higher flows it runs fine.
Is my water pressure switch going bad?
I looked at the heater manual and I read the adjustment procedure for the sensor should I try to reset it?
Thanks guys.
Thanks guys.
