I had an algae problem and been dumping liquid chlorine for the past few days. The water got better from how it was when I started, but still, has a green tint, normally after 3-4 bottles of chlorine, it turns blue. I brushed the walls to remove the algae, but regardless it stays the same color for the past couple days and kinda cloudy as well. Also, my pool pump pressure is low, showing around 3-4. It used to be around 8 for the past several years.
This January I cleaned the filter using TSP for the first time and ever since it shows 4 or below. I cleaned up all the debris from the skimmer and strainer basket, then the pressure bounces to 4-5 until next morning and it drops again. Currently, it's around 3 and raining since this morning.
This is my reading from an hour ago.
FC: 3 ppm
CC: 0.5 ppm
PH: 7.4 ppm
AL: 70 ppm
CH: 150 ppm
CYA: 40 ppm
I know I am slightly off on AL and CH. But does that cause the green tint or do I need to keep adding more chlorine until it turns blue? Should I hold on until the rain stops since that will throw off all the numbers? It's supposed to rain all day today.
FC: 3 ppm
CC: 0.5 ppm
PH: 7.4 ppm
AL: 70 ppm
CH: 150 ppm
CYA: 40 ppm
