I have an above ground Intex Pool - 18ft x 48in with Sand Filter. This is our 2nd season. Last year we tried to manage the pool with pool store chemicals. This year I am trying the methods on this site. We fill the pool with well water. We know it has iron. Here is this year's history: Filled the pool around Memorial Day. As the pool filled I added a quart of OmniPool "super metal out". The water stayed clear the entire time. (Last year I did not add the metal out until after filling and the pool turned orange as it filled.) I started the filter and ran two days before adding any bleach. When I added the bleach the pool clouded. Not green - but more of an aqua/blue. The water didn't look gross like it does with algea - but you could just barely see the bottom. I figured I needed to just keep filtering. I had a high TA and PH reading initially so added some muratic acid to get to the levels recorded below. I also added bleach to bring the chlorine level to 4.
Three days later the pool started to get more of the green tint to it. My test showed what I took to be .5 Combined Chlorine. Since I had not added any stablizing acid and the test was showing next to no acid level, I shocked the pool at a chlorine level of 11. After a day at FC 11 the green left and I could again see the bottom of the pool but it still kept the hazy aqua color. Completion of this brief SLAM was about a week ago. Next I began slowly adding stabilizer. I DO HAVE ONE BIG CHLORINE TABLET IN A FLOATER. We had some left over from last year that I didn't want to throw away!
June 9 test:
FC 4.5
CC 0
PH 7.2
TA 150
CYA <didn't register>
CH 220
I added approximately 20 oz of stabilizer at this time.
June 10 test:
FC 6
CC 0
PH 7.4
TA 150
CYA <with the 20 oz of stabilizer I was able to get a close to 30 reading>
CH 220
June 12 test:
FC 4.5
CC 0
PH 7.4
TA 150
CYA <did not test this morning>
CH 220
The only other comment I have is I'm not sure my CH test is accurate - when I add the drops it has little dots of purple that swirl in the water and after enough drops to get the test I'm recording the color is more purple than blue. I read this is a result of the iron in the water(???) THE FILTER HAS RUN NON-STOP SINCE FILLING THE POOL. BACKWASH IS GETTING SOME RUST COLORED WATER - WHICH I ASSUME IS IRON RELATED.
My questions:
Is this an unresolved iron issue? (One quart is labeled to treat 10,000 gallons, last year a quart seemed to clear the water. This year I've used 1 quart plus just a few ounces for 7600 gallons. I have not gotten an official iron test.)
Is this a water balance issue?
Is this an algea issue? (There is no slime on the sides or bottom of the pool.)
Or something else...
I'm new to this... so I realize I may be overlooking some vital piece of info. I'm at the point I'm afraid I'm making assumptions what the problem is that may be incorrect. Thanks for any pointers.
June 9 test:
FC 4.5
CC 0
PH 7.2
TA 150
CH 220
June 10 test:
FC 6
CC 0
PH 7.4
TA 150
CH 220
June 12 test:
FC 4.5
CC 0
PH 7.4
TA 150
CH 220
My questions:
