Your chorine is low and algae has probably formed. Your PH is good for a SLAM. Can you get liquid chlorine? Perform the Overnight Chlorine Loss Test linked below before you determine what might be happening. With only that test kit you are flying a bit blind because you need to know your CYA level too. Pool Care Basics FC/CYA Levels PoolMath Overnight Chlorine Loss Test SLAM Process
