Hello,
I am a new pool owner. Pool was built in 2004, and I moved in to the house two months ago.
We had a storm last week, and since then, the pool is loosing around 2 inches of water every day (I used a tape to measure). The water level is now below skimmers and jets and it continues to drop. I feel the water is leaking inside the liners because I noticed that there is now a space between liners and pool wall. I checked the pump I did not identify any leak or wet soil. I called leak detection company and they will come next Friday; however, they want normal water level which is not possible with continuous water loss and not ideal since the water will go to waste, and they want water temperature at 78 which what the heater is doing now (I assume it will take 24-48 hours in this cold weather).
If there is a liner crack, how can I fix this? Where is water going? Is it go underground? Will it affect my house structure?
Thank you.
Thank you.
