Hello!
new-ish pool owner ( came with the house ). the in-ground vinyl pool has a leak, leak/s. it is currently stopped at a level below the drain line. I am guessing it might have come from when I pulled out the umbrella from the pool in the last thunderstorm (blew over). I was able to find one leak and marine-caulk-seal it, but there is a leak somewhere else and my dye/diving skills can't find it.
I am hesitating to keep filling up the pool, concerned it might just be going to the foundation or somewhere else.
I've requested for service, but the earliest they can come is in 5 days. Any tips on how to maintain the pool till then?
i.e. just keep adding chlorine, maintain levels? is the pump ok to not run for that long? ( will i get other issues with the water stuck in the lines? ) should i start pumping from the pool into the skimmer basket or drain line?
thank you!
thank you!
