- Jun 26, 2018
- 185
- Vinyl
- Hayward Aqua Rite (T-9)
So took some water to get tested at my local pool supply store. Results are below:
Free Chlorine 7.19pmm (2 - 4ppm is suggested range)
Total Chlorine 7.73ppm (2-4ppm)
Combined Chlorine 0.54ppm (0 - 0.2ppm)
pH 7.9 (7.2 - 7.6)
Hardness 103ppm (150-275ppm)
Alkalinity w/stabilizer correction 83ppm (100-150ppm)
Cyanuric Acid 35ppm (50-100ppm)
Copper 0
Iron 0
Salt 3700ppm (2500-3500ppm)
In brackets are the suggested ranges.
They are suggesting:
- 3 cups / 1.4kg of Stabilizer
- 2 Cups of PH Down
- 1 Pouch of Shock N Shine
Next day:
- 4 kg of "buffer" (10 cups in total, 5 cups in morning, 5 in evening)
A few questions:
1. I have some shock pouches and muriatic acid at home, need to buy some baking soda (if I can find a bakery that sells it in bulk) and bleach. To translate the recommended stuff above into bleach, muriatic acid, baking soda etc. do I use the TFP app?
2. My Hayward system tells me the salt level is 3200ppm. Assuming the lab results are more accurate, is there a way to calibrate the Hayward system so that it reads 3700?
3. I'm going to be away until Tuesday, can this wait until then?
I don't have a TF100 test kit yet, hard to locate in Toronto Canada.
Thank you!
pH 7.9 (7.2 - 7.6)
Copper 0
Iron 0
- 2 Cups of PH Down
Next day:
A few questions:
Thank you!
