Ok thanks. I tried earlier but was unable to turn it any further than the way I have it in the pic. I am unable to lift the lever as it will come off when I tried as for some reason it is not secured as the center button is missing."Is this correct or do I need to go 90 degrees right so that the off is facing the heater pipe? I tried but was unable to go further right. If I try and lift the handle, then the handle comes off?"
YES. That is what I have been trying to tell you. Sorry if I lead you astray some how.
Lift that handle slighty, it has a bumper to stop you from turning it that way off/closed. Lift the handle over the bumper and face it towards the heater pipe. And the same with the other valve.
If you can not turn that valve freely back and forth while lifting slighty its clogged by a stick or something and that is the problem. I know for sure one of thos valves is bad, or clogged. I was just trying to teach you how to test if your spa body was leaking or not. My guess is that it is not. Plan on buying at least one jandy key assembly. If you ever manage to turn both those valves in the off/closed position you prolly will not lose any more spa water. Which means its one of those valves. If you cant turn that suction valve closed then its clogged by something. Open it and clear it out, Yes water will pour out on you from the spa on the return side. Maybe not so much from the suction side
There is a little red button on the side, not sure what that does. I will try again tomorrow. If I don't come right then I will open it up. This system was already here when we bought the house and it is a older system as you can see.
Thank you for all your help,
Gary
