Hi everybody. So right now I have a gunite pool shell that is still waiting for plaster. We actually had an appointment to do plaster about a week and a half ago and the plaster crew came out and cleaned the pool and cut all the pipe stubs … and then apparently they had some issues with their equipment and had to call it off so I was left with the same gunite shell with no plaster, but pipe stubs were all cut.
Anyways, today I noticed that the two drain pipes in the deep end are both filled with water and its spilled out enough to fill the dip around the pipe. It doesn’t seem like any more water is still continuously flowing out, but the pipes are basically filled to the brim with water. The last time I checked two or three days ago, everything was still totally dry.
There hasn’t been any rain at all recently and nobody has sprayed or added any water into the pool for a long time, so I’m a bit confused and concerned where this water may be coming from.
The pump was installed a while back and has never run, but I see a bunch of condensation under the cover as well (attached a picture). Although that condensation has been there for many weeks at least.
I’m wondering if this may indicate some kind of leak or issue with the plumbing? Has anybody seen anything like this and know what may be happening?
Thanks!
Thanks!
