Water coming into pool after pebble
Tim.mobley1711
1
Georgia
My Pebble was completed today and I noticed a spot in the pebble that was leaking water into the pool from ground water.
This area was a visible leak in the shell before the pebble that was supposed to be covered with hydraulic concrete before the pebble.
Is it a problem? Or will this fix itself once pebble cures?
Thanks
Welcome to TFP.
Do you know if the hydraulic cement was put on?
Thanks
If there was a crack in the concrete shell below the finish and it wasn't addressed properly, putting a "band aid" over it won't help. If the shell moves even a little the hydraulic cement would crack as well.
Reactions: .ben
I assume this is a new build, not replaster?
How much (%) have you paid?
Plaster is not self-healing.
