FC - 11.5
CC - .5
pH - 7.6
TA - 125
CH - 175
CYA - 80
Water is cloudy (can see bottom of deep end (8ft)) but not clear and has a green tinge to it (not like a dirty pond or anything, just not the beautiful blue it normally is).
So a little (or a lot) of background info....I've spent countless hours reading all the wonderful info you all have available and I'm really struggling for 1 main reason. Our pool was completed in Oct. 2018 and then closed (without being used) for the winter and opened on May 1, 2019. Once the pool was opened (by local company) we got the water temp up, added salt, turned on our SWG and no FC was produced. Pool store test indicated not enough salt despite our SWG saying 3.4. Added salt, emailed Zodiac for instructions on how to recalibrate salinity on SWG and had water tested. Salt at 3.5, calibrated SWG to 3.5 and still no FC. Called Zodiac. They told me to shock the pool, boost the SWG for 24 hours and test. That was 2 weeks ago and still no FC. Zodiac agrees something is wrong with our SWG (which is under warranty) so we contacted pool builder. They can't get out until June 21st, go figure, and want me to try all sorts of things in hopes the SWG will work. I feel like they're jerking me around, but that's neither here nor there at this point. I have a salt pool which should be fairly easy, but I feel I need to convert to liquid chlorine so we can safely enjoy our swim season. As a side note, I have your recommended test kit now and that's what yielded the results above. I had pool store test this morning (my kit arrived this afternoon) to ensure everything was ok prior to shocking, on their tests everything was fine. Since then FC has obviously gone up (.5 to 11.5), TA gone up (91 to 125), CH gone up (152 to 175), CYA gone up (75 to 80) but I have no idea if that's a result of the shock or bad test results?! An why is it turning cloudy and green?!
I felt I needed to follow builders directions, since they are the ones I need to convince that it's not working. So, they told me to backwash and then add 6 lbs of Sodium Diochlor. They told me to turn SWG to 50% and test chlorine twice a day. If it starts to fall then SWG isn't working. So today at 2pm I added the Sodium Diochlor and now my pool is cloudy and green tinted. Test results above are from 7pm today so 5 hours after that shock.
Would you all recommend I follow whatever advice you may give to get my water balanced as a liquid chlorine pool while I wait for pool builder to get out here and test the SWG? If I do that, how will they know that the SWG isn't working if I've gotten the chlorine and water all straightened out? They were horrible during the building process so I wouldn't put much past them.
Most importantly, it's our daughters 9th birthday and she's having her birthday party this weekend and I'm desperate for her sake to get this sorted out. Pool builder tonight suggested I just throw chlorine tabs in the skimmers tonight to get me through the weekend, but with a green cloudy pool I feel I have more issues.....PLEASE HELP!
CC - .5
pH - 7.6
TA - 125
CH - 175
CYA - 80
