Hi all, new poster here, so I apologize if this is a duplicate entry in the forums. I could use some help with water testing and balancing.
My pool details:
My local pool store uses the SpinTouch WaterLink system, and it said to add 2 lbs of pH UP for 30,300 gallons. When I look at the Pooli or Leslie's apps, they say to use 6 lbs of pH UP for 30,300 gallons... who is right? Why the difference?
My questions are these:
My pool details:
- Outdoor (covered with automatic safety cover 24/7 unless in use)
- In-ground
- Vinyl-lined
- 30,300 gallon, Grecian-style
- Bromine sanitizer
- Pentair equipment (pump, DE filter, heater, in-line chemical feeder for bromine tablets)
Pool Store (7/9/24) | Value | Reagent Kit (7/10/24) | Value |
Bromine | 4.23 | Bromine | 5 |
pH | 6.7 | pH | 6.8 |
Alkalinity | 115 | Alkalnity | 150 |
Hardness | 150 | Hardness | 200 |
- Why would the results be so different on some of the readings?
- What is the best/most accurate/most reliable testing method for home users (strips, reagents, etc.)
- Any recommendations on good pool apps that will help with recording test results and giving recommendations for chemical additions?
- As mentioned above, I've been using Pooli and Leslie's, and they seem to be pretty similar as far as chemical recommendations.
