Hello, It's pool time here again and I am still adjusting my new water after getting a new liner last Fall.
It seems I lost quite a bit of CYA over the winter (now 20 instead of 30ish). I opened with dichlor to raise it a bit but it doesn't seem to have done that, unless it doesn't register correctly for a few days? PH is about 7.4. Alkalinity of the new water came in high and is around 130 now. Shall I just wait for my PH to go up and then bring down the alkalinity with that OR should I do it now and then increase the PH? I like making conservative changes.... Also would the CYA increase show within 12 hours or longer with the dichlor? I will resume with liquid chlorine once I get back into range. thank you as always.
