Prior to this, it’s evident I had air getting into the system, the return jet in the deep end outputs air. I have linked a video of both jets and the filter. The other jet in the shallow end seems fine. It should also be noted the concrete around the pool is being redone so it’s safe to say there was also shards mixed in with the leaves.
This most recent vacuum session, I was getting the leaves at the bottom and there was a change, I lost suction. When the hose is disconnected, the system seemingly works fine, pressure is just under 15. Now, when that hose is attached, even without vacuum attachment, the pressure is around 3 psi. The vacuum hose line seems clear, but I guess I can’t be absolutely sure. Is the culprit most likely when vacuuming the last time I worsened the air leak and now when the hose is attached, it makes the problem even worse? Anyone have any ideas?
Thanks
Thanks
