Our single speed pump has started leaking. We can probably fix it quite easily, but reviewed the operating costs of the pump and have opted instead to upgrade the pump to a vs model. We had a technician provide a bid and make a recommendation on which pump to install. We were pretty shocked at the bid we received - $1300 to purchase and install a Hayward Max-Flo VS Pump 230 Volt rating. I'm pretty sure i found the same pump on Amazon for about $650, and from what I understand installing a pump isn't that difficult, so we are not having the work done by that bid provider.
What I am trying to determine now is whether the recomended pump is a reasonable replacement- can someone help me with that? im concerned because I have read in a few places where people have a tendency to buy a larger pump than they really need, and I wondered whether I was at risk of doing the same? Most of my pool details are in my signature, but I can provide more detail if it's needed. The equipment and pool are within 10 feet of each other on flat terrain (if that matters). Thank you.
