Just purchased the warrior SE and I’ve used it over the past 2 days and it doesn’t seem to be cleaning the whole pool. It’s missing big areas of the pool. Is it supposed to map the pool it’s first time out? Did I do something wrong? Any advice?
No it's not the norm but can happen from time to time.Is this common with pool robots?
Fortunately you can get them with a 2yr warrantyNo it's not the norm but can happen from time to time.
I don't have much on my floor either, but what I do have it isnt picking up. I let it run for the 2 hour cycle and still not picking up 50%. Do you think its not working right or is this expected? Seems like a lot of $ for 50% pick upL,
It does not really map anything in the way we would normally think of it.. It starts a new "map" every time it is turned on.. It has a crude idea where it is and tries to not cover the same area over and over again.
I have three robots in three pools and can say that if I have a single leaf, the size of a dime, they will find it and pick it up every time. That said, the only way I have to tell if the cleaner is working is by the lack of any debris. It is not like I have so much stuff on the floor of my pool that I can actually see where the robot has been, and where it has not been.
Also keep in mind the the robot will not climb the wall every single time.
I do know that it will not pic up things if you are "looking at it"...At least every time I have been watching, it will drive right past the same leaf until I go into the house.. when I come back out, it will be gone..
If you can see tracks on your pool floor, I don't think that is a robot problem..
I would call the seller and see what they have to say.. I don't think you can do anything wrong.
I thought I was the only one who noticed that...lolI do know that it will not pic up things if you are "looking at it"...At least every time I have been watching, it will drive right past the same leaf until I go into the house.. when I come back out, it will be gone..
