- Jul 21, 2013
- 65,567
- Plaster
- Pentair Intellichlor IC-60
That shows the conduit only has a 120V power cable to the Aquarite.
No data cable to connect with the Omnihub.
I do not have a multimeter. If this isn't the cause, do you have an idea as to what else would cause this? Wouldn't I expect to see the no flow light on even if the cell was damaged? I unplugged the connection and back in. The no flow flashes for a bit but goes away. It does seem like it probably isn't turning off. Do you think the heat fried some of the internal components?Do you have a multimeter and know how to test ohms or continuity?
Circled in orange on the lower left is the flow switch for your Aquarite. If you follow the wire it should connect into the bottom of the panel.
Unplug the flow switch cable form the panel and put your multimeter probes on the center two pins - 3 & 4. You should find the switch is open when the pump is off and closed when the pump is on.
If the switch is closed when the pump is off you need to replace the flow switch.
The pump was off.
I think my cell is dead or damaged too much. It won't register the instantaneous salt levels and the inspect cell and check salt lights are solid.
Auto to offThat confirms your flow switch is stuck closed and needs to be replaced.
Connect the cell and run the pump and tell me the diagnostic information.
This is the basic information we need to know in diagnosing a problem:
- Report all diagnostic readings when you..
- Move the switch from auto to off and check all of the readings.
- Move the switch back to auto and recheck the readings.
- Move the switch to off for a minute and then back to auto and recheck the readings.
- What are the first seven characters of the cell and box serial numbers?
- What is the actual salinity and how are you measuring it?
Yup, your cell looks dead.
You do have an AQR940 controller which means it can be connected to the OmniHub using the HLAQRPCB board.
It is interesting that your board says AL-1
Move the switch to auto and momentarily push the diagnostic button to display the Product Name "AL-1". Then move the switch to Superchlorinate and back to auto 3x or until the desired AL-0 is shown on the display.
- AL-0 is AquaRite.
- AL-1 NatureSoft.
- AL-2 MineralSprings.
- AL-3 SmartPure.
See if that makes any difference in the other cell diagnostics.
I suggest you make another warranty claim with Hayward with that cell as the serial number says it is a 2024 cell with a 1 year warranty.
2700 is a marginal salt level. I suggest you get your own K-1766 salt test kit - Salt
Also, thank you for the help. I really appreciate it. It's nice to finally have an idea what is going on.Yup, your cell looks dead.
- AL-0 is AquaRite.
- AL-1 NatureSoft.
- AL-3 SmartPure.
I have a heat/chill pump but the bypass valve is closed so it isn't going through the system right now.Are you using the heat pump?
It looks like the heater bypass is open.
Maybe the heater is running with no flow?
The problem does look like a heat issue, but I don't think that the cell gets hot from running with no flow.
It can build up gas and explode, but I have not seen reports of the cell getting hot.
Maybe it is due to sun exposure but that seems unlikely.
I believe the likely problem is a failure in the flow controller, causing the system to remain on after the pump has turned off. I'm unsure why it gets that warm to starts warping, but it seems like this could be a product defect.My cell does not run past 9 am and doesn't get deformed at all like this one did. Mine gets afternoon shade as well. I'm also thinking it's because the cell is still on the entire time the filter is turned off. Whoever diagnosed this before needs to own up to giving you another new cell and a flow switch.
