- May 26, 2023
- 6
- Plaster
- Hayward Aqua Rite (T-15)
Quick rundown, I had a 10 year old Ecostar 2.65? HP motor that went out. I chose to replace with a W3SP3202VSP TriStar 1.85HP. My pool is 10K gallon SWC, with no spa, and a pump for cleaner robot on Aux 1. I’m running Main Software Revision 4.40 and Display Software Revision 3.13.
I’ve tried following the instructions by removing the existing 4-pin bus to the pump controller and utilizing the separate provided bus bar to put wires 2-A(black) and 3-B(yellow) and then to the corresponding spots on the AquaPlus controller (2->Black, 3->Yellow). I’ve then put the Dip Switches to all off. At this point I get nothing, no priming, no action initiated from the AquaPlus panel. The panel on the pump doesn’t power up, but I’ve read that’s how it’s supposed to act when you’ve rewired for remote control as I’ve described. I’ve also attempted the COM port for the third wire and plugged into the a lot 4 on the AquaPlus controller, still nothing.
Worried the pump was a dud, I hooked it back up to the way it came out out of box, using the panel on the pump and putting the Dip Switch #1 to ON (came that way), it powers up, primes and runs perfect. So I put the connection back to the AquaPlus using the separate bus bar with that Dip Switch setting ON and OFF and still nothing.
Any ideas on what I’m missing here? On the controller the settings are the same as they were for the EcoStar, VSP mode set, everything.
Appreciate any help.
