New pool owner and trying to figure out the best schedule / speeds to set up for the variable speed pump. I am currently running 24/7, which is fine with me, since I tend to get a bit of debris in the pool from some nerby trees, but thinking I could reduce the speeds a bit and save some electricity. I know I might need to play around with it, but not even sure where to start as a baseline and the Jandy docs don’t seem to offer much guidance ... and neither did my pool builder.
Plaster pool
25K gallons
3 returns
2 skimmers
Jandy VSP 2.7hp (600 RPM - 3450 RPM)
Jandy DE filter (Max Flow Rate 96 GPM)
Nature2 Fusion Soft Salt Chlorinator (Flow Rate – Min 30 GPM / Max 120 GPM)
I also have a Polaris pressure cleaner that I have set to run from 9-1, but I have that off a booster pump, so don’t think that factors in.
Plaster pool
25K gallons
3 returns
2 skimmers
