- Sep 19, 2020
- 29
- Plaster
- Pentair Intellichlor IC-20
I could use some understanding of how to best set my vs pump to work best with my IC20 SWG. I currently have the VSP set to run at 2350 rpm from 6am to 6pm and 1200 rpm from 6pm to 6am. The lower speed in the evening is me trying to be economical and partially out of respect for my neighbor who would hear the motor if sitting out on their lanai after work.
My question is what is the best speed for the pump to work with my SWG? I have been able to stabilize my FC at around 7.5 - 8.0 but in order to do this I have been reducing my SWG to 10 or 20% output. Is it better to have the SWG at 40% and lower the speed from the 2300 rpm to maybe 1700 rpm or does one have nothing to do with the other? In case it's needed I have attached todays test #'s (working on lowering the PH but that's a work in progress).
Thank you
Thank you
