Hello TFP. Has anyone here run into this kind of issue, or have heard anything about it from elsewhere?
www.troublefreepool.com
So far it's the only thread anywhere on the web I've seen that matches the issue I'm currently having, but a solution was never found and the thread fizzled. Hopefully someone has anything to share. Thank you!
David
water flow slows down after awhile through pump
I appear to have a Dynamo 2HP pump with a Sand-dollar sand filter. I do not have a timer yet. After a couple of hours or so, the water flow is noticeably less coming out of the return. Also, from looking in the skimmer there is less 'suction'. The skimmer basket is not full, nowhere near...
David
