Hi all, so I recently switched to a VS pump, but I noticed at lower speeds the cartridge filter gets clogged faster. With the old 1hp pump, the filter would get cleaned a couple times a year and the flow wouldn’t really change.
Now at a low rpm I find a speed that looks like it works great, then a week or two later the flow drops off, I clean the filter and the flow jumps right back up.
I think I read here that at a high speed it’s possible for the pump to force particles through the filter? So at a low speed am I just now able to truly filter out smaller particles in the water?
Chemestry is fine, no algae and water is crystal clear. My primary water pollutant right now is dog fur and pollen.
I have skimmed hairnets but I took them out as I dialed in the new VS pump... I’ll have to try them again.
