- Oct 25, 2015
- 5,197
- Plaster
- CircuPool RJ-60 Plus
Folks,
I've had VS pump envy too long. I'd like to go with a new full-blown Pentair Intelliflo model but I tried all Jim Rahbe's arguments for this and it hasn't worked with my wife. Looks like the only option for me is the Century V-Green 1.65 hp. I'll be replacing my 1 hp Jandy pump motor with the VS direct bolt on. I'd also like to have it set up so that it runs on "high" speed (about 2800 rpm) only when my solar bypass valve is closed and "low" speed whenever the solar is bypassed. I'm trying to use the digital inputs for this without resorting to relays. I think I figured out a way but it seems too simple. Here's the plan, can experts weigh in on this please?
Chris
- The VS motor has a number of ways to control speed including 4 digital inputs called Step 1, Step 2... Step 4. They override all other control methods and they accept up to 30 vac or 15v DC.
- Looks to me the valve actuator wire that opens and closes the valve has two 24 vac lines plus a common. The valve is opened and closed by connecting 24 vac to L1 or L2.
- So I set Step 1 to be the higher and Step 2 to be the lower speed.
- Then I just split the solar valve actuator to go to the VS digital input panel.
- Connect L1 to Step 1 and L2 to Step 2 at the digital input.
- Power the pump with a relay powering the pump on my Intellicenter (same way it's powered now). This relay also supplies the Circupool relay with line power as a protection from being powered with no flow.
Chris
