I've recently learned that lower voltage at the pump will cause it to fail prematurely. What is an acceptable voltage at the pool pump with it running? My 1.5hp Pentair pump measures about 112 volts and 8.9 amps while running. Is this acceptable?
I'm concerned the wiring to my pump may not be sufficient, which could have caused the issue I experienced last summer: Pentair Dynamo Pump Quit Working | Trouble Free Pool .
