Use the 10 ml mark. It's good enough for our purposes. You also can get by with only scoop of powder. As long as you've added enough to see a few undissolved particles in the sample after mixing, there's enough powder.Good afternoon. My Taylor K-2006 kit arrived today!! I am already lost! The first test, Free & Combined Chlorine Test has a note:
For 1 drop = 0.2 ppm, use 25 mL sample. For 1 drop = 0.5 ppm, use 10 mL sample.
What level do I use? How do I determine that?
Pool School says: Fill the sample tube with pool water to the 10 ml mark. The top of the sample will be curved. This curve is called a meniscus. The bottom of the meniscus should be level with the 10 ml mark.
What if I should be using the 25 mL mark?
