10k pool. Got lazy and started using guess strips. Anywho I was getting a very low TA and high PH so I started adding Baking Soda. 10 here and 10 there and was still low so im thinking somthing is up. I buy the Taylor K-2006 and restest and discover my TA (375) and PH (red as can be) are sky high. Had some dry acid laying around (Sodium bisufate) so dropped about 3 lbs in. Ran for 48 hrs and readings still sky high. Understandable since they are so high. I grab 2 gallons of Mueratic Acid. Mix half a gallon in a bucket with water then drop in pool. Mix other half gallon and again drop in pool. Right then I remember your not suppsoed to add that much at once. Do some google detective work and confirmed.
Anyways after all these fails Im just wondering if adding htat much is critical. Not gonna make that mistake again but is there anything I should do or just let it run another 24 or 48 and test again and then add SLOWLY until I get desiered ranges? Thanks
