- Mar 19, 2021
- 186
- Vinyl
- Pentair Intellichlor IC-60
Since pool was built last summer, my Intelliflo was running fine but always 1/4 full of air (down to water intake level). I had read here it meant I had an air leak. Discuss w/PB who dismissed it as normal byproduct of VSPs. I then read loads of posts on this forum stating that it's perfectly normal, with many ppl experiencing that while running their VSPs at low RPMs... so I gave up and let it be.
Wanted to post my experience, hoping it helps someone else, because I do not think it is normal and two seasons later I now fixed it (which itself I suppose proves it isn't normal - meaning you shouldn't have a ton of air in your pump just because you run it slow). It bugged me so much that, after all sorts of soap and shaving cream tests, I took apart every single piece of equipment and plumbing - cleaned, lubed and tightened everything back up. And voila, the Intelliflo now runs with a basket completely full of water at my regular low speed (25GPM). There are a couple tiny bubbles in there, and they do seem to grow in size over time a bit, meaning probably there's still some air leakage somewhere else I still haven't fully addressed, but I went from 25% air to maybe 0.05% air in the basket now.
In my case, properly lubing/tightening all parts might have marginally helped, but I found that the main air gap was at the intake of Intelliflo where the suction-side union is. I had only ever checked/tightened the union and its o-ring (and clearly so did the PB who installed it last year and checked it thereafter). But today I noticed that the smaller threaded section of PVC that screws into the pump was not very tight and had another o-ring on that side too (sealing it to pump). In my case, that was it. Made the difference between pump running 1/4 to 1/3 full of air at all times, to now being just water.
So, no. Don't believe that you should have air in basket just because your VSP runs slow. I think the folks who say that just haven't found the cause yet. (Now maybe the air in basket doesn't materially affect performance/reliability and you can safely ignore it - that I don't know - but it's not a feature of a VSP!)
