Recent I purchased an IntelliFlo3 VSF. This thing is absolutely amazing and efficient. However, I learned real quick that heating at low speed caused my heater to run WAYYYY longer than normal. Which cost me a ton compared to normal start-up. Which also outweighs the extreme cost savings of this pump. Which is massive. $80-100/mo based on the app watt usage. I noticed that pentair has an IntelliConnect that allows you to hook up a heater and temperature sensor. Does anyone know if I can automate my setup with this? That way I can run it at extremely low speed while the heater isn't on, and when it runs the heater based on the temperature sensor, run the pump at the highest flow rate my heater is rated for?
