Hello all,
I have an Esther Williams 24' round above ground that my dad, brother and I installed ourselves probably 20 years ago, when we were kids. I ended up buying the house and the pool still stands. We replaced the liner last year and it's had a couple pumps.
The original pump was a 2 speed, and we always ran it on low 24/7 unless the vac was hooked up. It now has a Hayward Power Flo Matrix. The pump is a beast, but it's a single speed and hard on the wallet (even running it on a timer).
I'm considering changing it out for a 2 speed again, but my parents new house in Florida has a pentair VS motor on their inground pool... it is super quiet and sips electricity.
Looking around, I found Hayward makes a VS for above ground pools, but no one seems to carry it. Other than that, in not seeing much.
2 questions:
1. It's it worth pursuing a VS pump, or do I settle on a 2 speed?
2: Can I use an inground pump? I know the biggest difference is an inground pump needs to be able to prime which is not necessary with an AG pump, but im also wondering if you can mount an inground pump right next to the pool, like my current pump is.... I'm thinking in terms of can it get wet, or is it designed to be in a dry separate area?
Thanks for your help, and if anyone has suggestions, I'm open to anything!
Also I'm in a cartridge filter.
2 questions:
