OK, so variable speed pumps are more efficient at lower speeds. So which would be the better choice, a 3HP intelliflo VS running at 1000rpm or a 1.5HP superflo VS speed running at a higher speed (2000 rpm?) for the same flow rate.
Or, in accordance with the laws of thermodynamics, would they both use the same energy to pump at the same GPM?
Thanks!
Thanks!
