My power rates are constant. They don’t have peak and non peak rates so that isn’t a factor.
Running the pump wide open 24/7 for that matter really isn’t a cost concern either.
That being said I read ideally the water should be turned over once a day. With my 32k gallons 23GPM running around the clock would accomplish that. I believe my salt cell needs a minimum flow of 25 GPM +/- 5 GPM to work properly.
I don’t know how accurate it is but with my pump wide open at 3450 RPM screen logic reports 70 GPM And 2365 watts used. This would cycle all the water in 7.6 hours or three times a day.
Turning the pump down to 1950 RPM reports 30 GPM, and 410 watts used. This would cycle all the water in 17.8 hours.
My main pump draws only from the two skimmers. My auxiliary pump for water features pulls from the main drains. Skimming action seems much better at 70 GPM than 30.
From a purely power consumption standpoint 8 hours of 3450 RPM uses 18,920 watts. 24 hours of 1950 RPM uses 9,840 watts, roughly half as much but at the expense of what seems to be weaker skimming.
What should I set the darn thing at? I really don’t care about the cost I just want what is best for the pool. Is there any benefit to turning the water over three times a day vs just once? I don’t want to just be wasting money for no reason with no benefit but if it it is better to cycle it more I don’t mind the cost.
