So, having difficulty understanding a new set up...
I 'had' a plain old DE filter with a timer. Timer threw power on, pump came on. Used liquid chlorine. Timer shut off, pump motor shut off.
Now I have a Hayward VS pump and a Pure Chlor SWG. I assume I need the timer still. I tried programming the pump to run a schedule, but when it shuts off the SWG stays on, and indicates a water flow warning. That's bad, right? I can't leave it that way. Hence I need to use the original timer to kill power to the SWG.
Unfortunately, the timer kills the power to the VS pump too. Will it remember my settings, or move back to a default speed?
New equipment, and I'm floundering. Thanks so much for any help you can provide! Sincerely appreciated!
Mike
Mike
