I drained my pool equipment before the big freeze in Dallas and protected all of my equipment. However, my waterfalls are in a raised beam and above my valves. Clearly the valves retained water which of course froze! Next time I will know to remove the face of the valves. Only one valve body cracked but I need some suggestions on how to change the right most valve body. How do I deal with the top terminating directly into the tee? I am hopeful I don't have to redo the entirety of the manifold. Will a standard size pipe fit properly into the valve body if I cut it off at tee? Your expertise will be greatly appreciated.
