- Jan 9, 2024
- 30
- Plaster
- CircuPool RJ-30 Plus
Yes great tips. I did consider the possibility of the pump ramping up too high as soon as I saw what a monster it was at 100% when first powering it on after the install lol. I immediately looked to see if there was a way to limit it, and thankfully there are a bunch of limit parameters in the app. I set limits of 80 GPM (lowest it will let you set for the 3HP), 75% RPM, and also lowered the prime speed to 75%. I tested what the fastest possible speed I would ever need could be by opening up both my solar and suction cleaner valves then ramping the pump up to where the cleaner looked to be moving at the correct speed, which was just below 75% power.
