F,
Thanks for the extra pics..
If the plan was to make something that should simple as complex as you can get. You have succeeded...
The valve that is after the heater and before the SWCG, is just there to by-pass the SWCG. It really should be set so that all the water flows through the SWCG. I can't think of any reason that you would want to by pass the cell.
Anytime you add things to the flow path, the pump will have to run faster.
I am not really sure what you are trying to do.
You do have another valve, the one right after the filter. This valve is a heater by-pass valve. If not using your heater, you could run at a lower RPM and still turn on the SWCG. But... With a leaf catcher on the suction side of the pump, and a pre-filter on the pressure side of the pump, I am surprised that you don't have to run at a pretty high RPM to get your heater working at all.
Is this a new pool or has it been this way for a while? If an older pool, how did it work last year?
Tell us what RPM you normally run.
Tell us more about how you want your system to work.
And just so you know... Your cell is incorrectly installed. The flow through the cell "must" be going up when installed in the vertical position. Your flow is going down. The problem with this installation is that if the flow switch fails, it will fail closed and allow the cell to generate when there is no flow. This has nothing to do with the problem that you currently have.
Jim R.
